MsHewitt69@Gmail.com
#1 Posted : Monday, March 29, 2010 10:32:20 AM(UTC)
NO HEAT.
We Just Bought a W&D set just over a year ago:D Now we brought the old Drier back in to use.:( Come to find out the drier just went out of warranty.:eek: Now they want alot more money to fix the new drier.:mad: Kennmore use to be a GREAT brand, now not even a good brand.:cool: RUNS without HEAT.
#1 If the fuse is good an home fuses/breakers are good. What to do next?
#2 If fuse is bad. Does that mean there "IS" a problem somewhere in drier? Can it just go bad due to a power or heat surge?
#3 If the fuse is bad.Do I have to remove the heater core an look for breaks an grounds?
I'M disabled and doing it myself. Need the least expensive and easiest to do myself. Thanks for any helpful info:)
#2 Posted : Monday, March 29, 2010 2:25:18 PM(UTC)
What is the complete model number of the dryer?
