3 Pages<123
drl213
#21 Posted : Saturday, March 27, 2010 6:20:19 AM(UTC)
drl213
completely frosted. In fact, it's blowing "snow" all over the freezer. It doesn't normally do that.
#22 Posted : Saturday, March 27, 2010 6:44:06 AM(UTC)
If your defrost circuit is ok, you have another bad motherboard, put a 1000 joule surge protector in as I suggested before.
drl213
#23 Posted : Saturday, March 27, 2010 9:49:37 AM(UTC)
drl213
Ok, I replaced the motherboard but it would not manually defrost. I put the old one back on and it won't manually defrost either. How do I isolate which part of the defrost has the problem?
And just as a side note because I'm trying to understand how it all works, so even though the freezer isn't frozen over (as it has sometimes been in the past since) because I defrosted it last night with a blow dryer, shouldn't the refrigerator section be cold and working normal until the icing of the freezer happens? I thought the cold air was supposed to blow up into the refrigerator once the defrosting is complete, but maybe I'm not exactly understanding how it's all supposed to work. Anyway, thanks again for all your patience and help. At one point I considered maybe getting a new one, but there really is something satisfying about fixing it yourself (with an experts guidance.)
#24 Posted : Saturday, March 27, 2010 1:34:00 PM(UTC)
You might have a blown open heater if defrost failed.
drl213
#25 Posted : Saturday, March 27, 2010 2:01:42 PM(UTC)
drl213
How do I check it?
#26 Posted : Saturday, March 27, 2010 2:20:06 PM(UTC)
If a single coil heater, it's probably blown open, GE whent to a two coil heater. Look at the inside of the glass, if it is dark with a clear area, that's the area where the coil opened.
drl213
#27 Posted : Saturday, March 27, 2010 4:04:39 PM(UTC)
drl213
Ok, not to sound dense, but I'm not exactly sure where to look for that. On this diagram, would it be somewhere on #826? If not, where should I look for it?
Cabinet replacement parts for General Electric GBS22HCPAWW Refrigerator | AppliancePartsPros.com
#28 Posted : Sunday, March 28, 2010 12:09:17 AM(UTC)
Right under the evaporator, held on with two screws.
3 Pages<123
