Kebmike
#1 Posted : Monday, April 21, 2008 6:56:25 PM(UTC)
Kebmike
Dishwasher touchpad operates inconsistently. At times, it will work perfectly. Other times some of the touch pad keys are dead. For example, when trying to set a timed delay start, the keys are not functional, but I can start a normal cycle immediately.
At times, even normal cycle immediate start key will not function and will only start on heavy cycle.
I am assuming that the likely problem is the touch pad/console (part # AP3044891 in black) and not the electic control panel (part # AP3044855).
Would appreciate any advice from Gene or others.
Thanks in advance. Mike
bambiblaster
#2 Posted : Tuesday, April 22, 2008 2:24:10 AM(UTC)
bambiblaster
Yes should be the touch panel that is bad
Kebmike
#3 Posted : Tuesday, April 22, 2008 5:44:52 PM(UTC)
Kebmike
Thanks! Much appreciated.
