Hi, in the process of trying to fix my dryer after taking it apart, I realized that my problem was the thermal fuse. Now my problem is that when I was putting her back together, I accidentally tore a part of the ribbon cable going from the front control panel to the circuit board on the top right side control box. There is 2 ribbon cables. One of the cables has about 10 copper wires and the one that I broke only 5 wires in it. I cannot for the life of me find this part anywhere. If anyone can point me in the right direction or even give me a part #, it would be very helpful. Thank You, Mike.
or if anyone knows where i can get a ribbon cable to replace without having to buy a whole new interface?
