Dbowls
#1 Posted : 18 years ago
Dbowls
My washer is slow fill up. I have checked the water coming out of the valve at the wall. I also checked the filters on the back of the washer. They all looked ok. Any help here would be great!
Thank you
Matt / APP Team
#2 Posted : 18 years ago
Matt / APP Team
Rank: Administration
Groups: Administrators
Check the voltage at the valve, if the coil isnt getting 110v it may not open. If it is getting proper voltage and the coils are not opening the the valve is probably bad. I could not find your model number, so if the valve needs to be replaced check to see if there are any numbers on the valve that we can match up!
