Groups ready for retrieval: Registered
All 4 igniters stopped working, I believe I need MODULE-SPK Part Number: AP4364254 Made by WHIRLPOOL which I got off your web site, but I'm wondering if some other part could be involved, like maybe all 4 igniter switches or 1 switch grounded out killing the other 3 burner's igniters?
Have you checked for 120 VAC at the wall outlet for the cooktop? If there is proper voltage then the problem is a bad spark module. The spark module Part number: AP4364254
