My maytag neptune washer will not spin when on the spin cycle. It is a front load machine. when on the spin cycle it will continue to agitate back and forth while the pump trys to pump out the water. when complete the clothes are very wet and a small amount of water is still in the barrel. it sounds like it is working but only agitating not spinning.
no the door lock light is not on and the door can be opened any time during this process
no the door lock light does not come on and the door can be opened any time during the whole process.
no the door lock light does not come on and the door can be opened at any time during the entire process./
the door lock light does not come on and the door can be opened any time during the whole process/
no the lock door light does not come on and the door can be opened at any time throughout the entire process/
Originally Posted by: gshurtz  My maytag neptune washer will not spin when on the spin cycle. It is a front load machine. when on the spin cycle it will continue to agitate back and forth while the pump trys to pump out the water. when complete the clothes are very wet and a small amount of water is still in the barrel. it sounds like it is working but only agitating not spinning. no The door lock light will not come on and the door can be opened at any time
