dennis.kull@sbcglobal.net
#1 Posted : Wednesday, March 24, 2010 5:14:04 PM(UTC)
The icemaker indicator light does not come on in either switch position. Water is not flowing into the icemaker, though it is through the door water dispenser. The auger turns, so power is making it to that section. Any thoughts or suggestions on how I can troubleshoot the problem?
FridgeDoctor
#2 Posted : Thursday, March 25, 2010 8:31:01 AM(UTC)
FridgeDoctor
Groups: Expert
Check to make sure the ice maker is plugged in. you will have to remove the ice bucket, then you will see a white colored wire insulation coming down from the ice maker, and will likely go behind a white colored cover plate, sometimes there is no cover plate, if there is, remove the plate, then check the plug. be careful you don't push it too hard, you might bend the plate that contains the outlet for the ice maker plug. If the green LED still doesnt light up, or if it flashes, you'll need to replace the ice maker. the chances of it being a wiring issue beyond that ice maker outlet are pretty darn slim.
Expert Refrigerator Repair Service in Chicago and Suburbs
GE Profile Arctica Refrigerator Not Cooling or Freezing But Running (Refrigerator & Freezer Repair)
by mGalicia 5/29/2012 3:15:30 AM(UTC)
GE Profile Arctica Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by Snap50 7/25/2011 6:11:51 PM(UTC)
GE Profile Arctica Refrigerator Freezer & Fridge not cooling (Refrigerator & Freezer Repair)
by CPaz 6/24/2010 5:38:43 PM(UTC)
GE Profile Arctica Refrigerator display not working (Refrigerator & Freezer Repair)
by tiaschof 6/18/2009 12:08:39 PM(UTC)
GE Profile Arctica Refrigerator (Refrigerator & Freezer Repair)
by cfafan12 5/9/2009 3:17:32 AM(UTC)
GE Profile Arctica Refrigerator Not Cooling Enough (Refrigerator & Freezer Repair)
by ic3nin39 9/3/2008 10:12:27 PM(UTC)
