Johnny G
#1 Posted : Wednesday, March 24, 2010 11:32:44 AM(UTC)
Johnny G
Whenever I use my kitchen sink, or drain it, the water backfills into the dishwasher? what is going on and what is needed to fix it?
Thank You,
John:( :eek:
#2 Posted : Wednesday, March 24, 2010 12:35:21 PM(UTC)
Sounds like your drain is partially plugged or the unit's drain hose is not installed correctly.
Here is a good dishwasher install sheet which shows how the drain hose should be set up.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=31-30515.pdf
