2 Pages12>
rijopiatt
#1 Posted : Wednesday, March 24, 2010 4:49:10 AM(UTC)
rijopiatt
My water supply to frig is on. Water flows from water valve (ice maker side) when I use direct 110V from a test cord. Supply line from valve to ice maker is not restricted. I manually filled ice tray yesterday and the ice formed but did not eject. I pulled the cover off the front and examined the geared wheel. I noticed one tab that holds the wheel on is missing, but the wheel seems to be secure. In the process of seeing if there was any play in the wheel the wire lever(activation arm?) began to rise, at which point the cubes began to eject from the tray. The cubes dispensed fine from the door dispenser.
What should I now check or replace?
Rick in Indiana
magician59
#2 Posted : Wednesday, March 24, 2010 6:49:35 AM(UTC)
magician59
Did you maunally move the gear, or did it move on its own?
rijopiatt
#3 Posted : Thursday, March 25, 2010 3:48:35 AM(UTC)
rijopiatt
I only attempted to move it front to back and there was no noticeable play.
rick
magician59
#4 Posted : Thursday, March 25, 2010 5:14:36 PM(UTC)
magician59
Cut a small piece of electric wire (about 6" long; #14 or a little larger) and strip about 1/2" off each end. Place one end in the test terminal on your icemaker, marked, "T", and the other end in the one marked, "H". (you may need to depress the door switch). Does the gear on the front start to move? If it does, let it go about 1/2 way around and remove the jumper. Does it fill with water?
microman1962
#5 Posted : Thursday, March 25, 2010 5:27:18 PM(UTC)
microman1962
the wire jumper works great to see if the i/maker cycles,one other thing i have found over the years is problems with "piercing valves", they get clogged at the feed pipe and cause pressure issues with the water valves , they dont close the valve properly because of low water pressure and cause water to drip into fill tube and freeze causing the valve to burnt out . i always recomended replacing with a shut off valve. and usually never had call backs related to i/maker no fill situations.
crouton
#6 Posted : Friday, March 26, 2010 11:33:24 AM(UTC)
crouton
if you jump the maker out and it works, check the line to see if its frozen, and change filter, does that mean the valve is bad. water not leaving the valve on the maker side, but it is getting to the door dispenser
rijopiatt
#7 Posted : Friday, March 26, 2010 12:25:37 PM(UTC)
rijopiatt
OK
I put the jumper wire in the "H" and "T" holes and the geared wheel did not move ( with door switch on or off, with wire lever up or down) and no water coming in.
What next?
Rick in Indiana
magician59
#8 Posted : Friday, March 26, 2010 1:16:16 PM(UTC)
magician59
Check for voltage. You should have 120VAC between the test ports "L" and "V". If there is, replace the icemaker.
rijopiatt
#9 Posted : Tuesday, March 30, 2010 3:54:46 AM(UTC)
rijopiatt
I checked for voltage, and I have 120VAC at the test ports "L" and "V". According to your email I should replace the icemaker?
The website lists part #35 Motor-module #AP3177342 and part #37 Motor-modl #AP435-9694. Which should I order, or is there another part I should request?
Rick in Indiana
magician59
#10 Posted : Tuesday, March 30, 2010 7:06:56 AM(UTC)
magician59
Replace the Ice Maker. I'm from Indiana. Grew up in Richmond. Where are you?
2 Pages12>
