I have a GE Zoneline 2100 PTAC. The fan does not blow when the switch is turned to either low cool or low heat. When switched to low heat, you can feel the heat being generated. The fan works fine on fan, high heat, and high cool setting. Thermostat works fine. I thought it might be a bad main switch so I replaced it and nothing changed. My next guess might be replacing the main control board. Can anyone help me on this? Thanks in advance.
For other people who may have this problem. I replaced the main circuit board (control board) and everything is working properly.
