Model NO. LRFC22750tt
The fan that at far as I can tell blows into the bottom freezer area. It up around the vents and on the plastic housing. If I use a blow dryer and melt it it usually last for about 2 days and the starts up again...
Any thoughts?
I also need a part number for the plastic door latch for the fridge door ( there are two in the middle one for each door)
Thanks for any help what-so-ever
