soulgong
#1 Posted : Sunday, April 20, 2008 5:02:04 AM(UTC)
soulgong
this is ge arctica side by side i'm having several different problems with this refrigerator. the frige side gets hot the ice maker doesn't make ice
or dispense water & the freezer side also climbs in temp. it does this on & off & then everything goes back to normal (everything works) & then in a
couple of days it's starts the same thing over again.can anyone help
thanks curtis
soulgong
#2 Posted : Thursday, April 24, 2008 4:08:35 AM(UTC)
soulgong
My Fridge Is Doing The Same Thing Again, Does Anyone Has An Answer For Me.
#3 Posted : Thursday, April 24, 2008 8:44:49 PM(UTC)
Originally Posted by: soulgong Go to Quoted Post
...i'm having several different problems with this refrigerator. the frige side gets hot the ice maker doesn't make ice
or dispense water & the freezer side also climbs in temp. it does this on & off & then everything goes back to normal (everything works) & then in a couple of days it's starts the same thing over again.can anyone help
thanks curtis
Curtis,
This is a situation which we called "Technician's nightmare" because it is almost not possible to diagnose a problem if it does not show up at time of diagnosis. Also, the problems you mentioned could have a very different causes.
