Craig319
#1 Posted : Tuesday, March 23, 2010 5:07:29 AM(UTC)
Craig319
I have a maytag washer A712, Yea I know it is old and I am not trying to get a new one just fix this. It will only run in the spin mode will not fill with water or agitate, just spin then stop, I took the panel apart and all lookes good. What to do Next....
magician59
#2 Posted : Tuesday, March 23, 2010 9:05:02 AM(UTC)
magician59
Does the motor run in the wash mode? Have you tried it in all wash cycles?
Craig319
#3 Posted : Tuesday, March 23, 2010 5:07:14 PM(UTC)
Craig319
No I do not here the motor running in wash mode it just works in spin.
magician59
#4 Posted : Tuesday, March 23, 2010 5:37:14 PM(UTC)
magician59
Then I would suspect the timer.
Craig319
#5 Posted : Tuesday, March 23, 2010 5:40:37 PM(UTC)
Craig319
is there a way to cross the wires on the timer to see?
Craig319
#6 Posted : Friday, March 26, 2010 5:51:14 AM(UTC)
Craig319
magician59
#7 Posted : Friday, March 26, 2010 8:55:40 AM(UTC)
magician59
You'll need a meter and the schematic. The schematic will show which wires at the timer to test.
Guest (4)
