alma1031
#1 Posted : Saturday, April 19, 2008 3:12:03 PM(UTC)
alma1031
My washer takes forever to fill up. As it is filling up is also spills out water from the bottom. This happen when it is filling up and when it is in the rinse cycle. It takes forever to put water in for the wash or rinse cycle. Can anyone help me out. Thanks
glen65
#2 Posted : Saturday, April 19, 2008 7:07:06 PM(UTC)
glen65
I’m assuming you have adequate pressure going
to the washer hookup lines themselves. Here’s
something you can try,
Disconnect the fill hoses from the washer
and at the water spickets they connect to.
If there are any filter screens in either end of
the supply hoses check them to see if anything
is restricting them, if so clean or replace them.
Hold a bucket up to each spicket and turn it on
for about 15 seconds in order to flush the lines
going to the spickets. If the pressure seems weak then
you may an issue with your water system that needs
to be looked into.
Check the plastic inlet valve hookups on the washer
itself. There are filter screens inserted into ends of the valve
hookups. Check to see if the screens are plugged or
contaminated. If they are you will need to clean them
(do not attempt to remove the screens from the valve).
You can use a small brush to reach in and clean the
valve screens if needed.
Reconnect the fill hoses back to the washer and
test the machine and let us know how it goes.
Hope this helps,
