:confused: Dryer starts heats and runs fine, but if you open door to add bounce sheet it seems to be stuck in run mode upon closing of door you here a moan not normal. Normally you have to push the start button. If I open the door and manually give the drum a push it will catch and run normal again. Start winding or capasitor?
THIS FORUM IS DEAD!!!!!!! |
Roper dryer RGK2951KQ1 There was dust, but the main problem was that 1 of the 2 springs of the centrifical switch had broken off so it wouldn't reset when hot. Spring back on and unit resets very time. Thanks for your help in pointing me in the right direction. Flitzr 1 :)
