drexanth
#1 Posted : Monday, March 22, 2010 12:56:49 PM(UTC)
drexanth
Due to a severe power surge and an unconcerned electrical company my duet GEW9200LL2 is not working.
I replaced the control electronics board (nothing was displaying), it then displayed E1.
Did the thermistor test and the diagnostics (per the repair service manual), replaced the thermistor and it still displays E1.
Checked and removed any obvious lint and the vent seems fine.
Any suggestions please. Thank you.
#2 Posted : Monday, March 22, 2010 4:53:25 PM(UTC)
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208541833.pdf
Did you check the new thermistor with a meter?
Also I would check the wires from the thermistor to the board for continuity.
