rbhayden
#1 Posted : Friday, April 18, 2008 9:05:01 AM(UTC)
rbhayden
When I start a cycle, the tank doesn't fill up. The water goes straight out through the drain pump and out the drain hose.
I recently took the drain pump apart, but I put it back together just the way it was.
Please help.
Thanks.
gearhead1218
#2 Posted : Friday, April 18, 2008 12:28:51 PM(UTC)
gearhead1218
Have you got your drain hose just laying flat and draining horizontally, or going into a standpipe or sink at about the same height as the washer?
If it's laying horizotally, that's your problem.
rbhayden
#3 Posted : Saturday, April 19, 2008 2:19:34 PM(UTC)
rbhayden
gearhead1218....thanks a million.
ddrowe
#4 Posted : Tuesday, April 29, 2008 11:36:47 AM(UTC)
ddrowe
Same problem but my hoses are not flat - it goes up into a drain. Can anyone help?
