bini_182001
#1 Posted : Monday, March 22, 2010 8:03:50 AM(UTC)
bini_182001
Hi Can anyone tell me how to fix right rear element for CFEF366EM range? its turning on but not at the highest capacity. Looking forward to a cheap solution.
#2 Posted : Tuesday, March 23, 2010 2:28:48 AM(UTC)
Replacement parts for cfef366em models | AppliancePartsPros.com
Here is a tech sheet for an EMF
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316441437.pdf
And a manual which should be close
http://frigidaireservicetips.com/pdfs/304_5995361523_NGInchFreestandingRanges_revA.pdf
Cannot guarantee cheap.
Most likely it is the control switch but could also be the element and its limiter.
You could swap the back left and right elements as they look the same.
If the problem stays on the right then that points to a control switch problem.
Be sure to unplug the unit when working on it, 240 volts is lethal!!!
