easanderson
#1 Posted : Sunday, March 21, 2010 8:51:11 AM(UTC)
easanderson
My freezerless refridgerator is one year one month old, just out out of warranty. It gets up too 47-49 degrees before it turns on and gets back to 36-38 degrees. Any help would be greatly appreciated!:confused:
#2 Posted : Monday, March 22, 2010 2:36:54 AM(UTC)
Replacement parts for fru17b2jw15 models | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/216946200.pdf
I am assuming that the evaporator coils are not heavily frosted/iced over as this would indicated a defrost problem.
I would suspect that the thermostat is the culprit.
Also check that the evaporator fan is running.
