bco3321
#1 Posted : Sunday, March 21, 2010 10:38:04 AM(UTC)
bco3321
Tested Defrost Timer, Continuity Good When Advancing Timmer Shaft , Defrost Thermostat Checks With Continuity When Warm And Then When Placed In Freezer, Defrost Heater,no Conitinuity,1/4" Tube Has A Crack On One Of The Bends Visually Hollow Inside, Continuityon Both Sides Of The Tube. No Continuity From Bullet Connctor To Tube Either Side
#2 Posted : Monday, March 22, 2010 2:19:40 AM(UTC)
Replacement parts for FRIGIDAIRE FRS26ZRGWA Frg(v3) / Refrigerator | AppliancePartsPros.com
Here is a wiring diagram/tech sheet.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/218909400.pdf
[COLOR="Blue"]Tested Defrost Timer, Continuity Good When Advancing Timmer Shaft[/COLOR]
Not sure how you measured this so cannot comment.
[COLOR="Blue"]
Defrost Thermostat Checks With Continuity When Warm And Then When Placed In Freezer[/COLOR]
This is a problem. The thermostat should be open (infinite ohms) at room temperature and closed (0 ohms) when frozen, see the tech sheet.
[COLOR="Blue"], Defrost Heater,no Conitinuity,1/4" Tube Has A Crack On One Of The Bends Visually Hollow Inside, Continuityon Both Sides Of The Tube. No Continuity From Bullet Connctor To Tube Either Side[/COLOR]
You lost me here.
The defrost heater should measure approximately 22 ohms, see the tech sheet
