mportobello
#1 Posted : Saturday, March 20, 2010 9:31:06 PM(UTC)
mportobello
I am replacing my thermostat. I've attached a photo of the existing wiring and new wiring.
1. Why is the existing thermostat wired backwards (R --> W and W --> R)?
2. Why is G (fan) controlled by a relay and switch located in the basement rather than the thermostat? Is it for mechanical 2-wire thermostats?
3. Is the new wiring reasonable?
R --> R
W --> W
G --> G
C --> C
Thanks for any help!
Brian
Other details:
Trane XE80 natural gas forced air furnace with White Rodgers 50A65-475 ignition control board
Current thermostat is a LUX 1500
New thermostat is a HAI RC-80
My place is a townhouse condo built 1999 in Calgary, Canada
If attachment doesn't work: FurnaceWiring
mportobello attached the following image(s):
