jdrake0304
#1 Posted : Friday, April 18, 2008 5:12:24 PM(UTC)
jdrake0304
the valve that allows the water to flow to ice maker is dry, no water in waterline. there is a flow of water from the water line
jdrake0304
#2 Posted : Friday, April 18, 2008 5:21:08 PM(UTC)
jdrake0304
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
ApplianceJunk
#3 Posted : Saturday, April 19, 2008 5:41:18 AM(UTC)
ApplianceJunk
Check the water fill tube that goes through the freezer wall to see if it is frozen, blocking the flow of the water.
jdrake0304
#4 Posted : Sunday, April 20, 2008 10:54:41 AM(UTC)
jdrake0304
the line in the back of the fridge is also dry,i check the valve to see if i was getting water to the valve from the water line,water was present at the valve but would not dispense from the valve,its there a solenoid swicth that pull the water to ice maker,water dispense
