This is an Admiral Refrigerator. The relay needs to be replaced. old one has electrical prongs at locations numbered 2 & 3. the new one has electrical prongs at locations 1, 2 & 3. Have double checked to make sure it is the correct part and they say it is. the old one had a black & white wire tied together that was then plugged into the number 2 position. And a single wire for the number 3 position. My question is, can I leave the wires the way they are and just use the number 2 & 3 position prongs like the old one, OR do I have to separate the black & white wire that used to be one prong position 2, and use the number 1 & 2 positions for those 2 wires? AND if I do, then in what position does the white and black wires go to? Does the black wire go to position number 1 or 2? and the same question for the white wire.
I would never use a substitute start/overload device that is not the factory specified part. The substitute part will never protect your compressor during power surges. If you still want to use this, you will need an ohm meter, post back when you have one.
I did contact the manufacturer and they said this new relay was the correct one for my refrigerator, even though the old one had only two electrical prongs in position 2 & 3 and the new one has 3 electrical prongs in positions 1, 2 & 3. When I asked them about the extra prong in the number 1 position and whether it needed to be used by splitting my combined black and white wires that were on number 2 prong, they said they didn't know and that I should contact a refrigeration person. so this is why i posted the question here. to see if anyone knew what i was to do. thanks for your reply but i don't think I really understood it.
Ask the supplier if they will guarantee the compressor will survive a series of power surges when using this substitute part! Get it in writing! If I where doing warranty work, and saw this substitute part used, I would not honor the compressor warranty period!
