dizymechanic
#1 Posted : Friday, March 19, 2010 8:33:19 AM(UTC)
dizymechanic
I recently replaced the oven igniter but have no power going to it ,In the schematics it shows a 5 amp fuse for each igniter (broil) and (bake) broil works fine but I cant find any fuses is there a fuse built in the gas safety valve and if so is it replaceable??
Thanks in advance Joe
#2 Posted : Friday, March 19, 2010 6:59:44 PM(UTC)
Joe,
Can you post the wiring diagram or schematics?
dizymechanic
#3 Posted : Saturday, March 20, 2010 4:21:24 AM(UTC)
dizymechanic
I think I attached it correctly
dizymechanic attached the following image(s):
#4 Posted : Saturday, March 20, 2010 4:32:35 PM(UTC)
In this diagram are covered a few different models. There are the relay board and control board shown in the parts list for the model number you posted. Most likely this model is shown in the bottom right part on the diagram you posted and there are no fuses at all.
Hi-limit switch shown there will interrupt power to both Bake and Broil if it's open.
I would check the Bake part of the gas safety valve for continuity and replace it if the circuit is open.
Otherwise the problem is a bad relay board (#18 on the diagram).
- The relay board Part number: AP4101943
