Denise in MN
#1 Posted : Friday, March 19, 2010 4:31:13 PM(UTC)
Denise in MN
I was not using my oven, when out of the blue, it beeped 5 times which caused me to look at it. The control panel was blank, there was no error message, nothing there. When I touch certain buttons, it beeps about 5 or 6 times but it still stays blank. I tried twice to reset the circuit breaker and each time I did, it would beep 5 to 6 times but did not light up the control panel. Is there a reset button on the oven or does this mean the control panel needs to be replaced? Thank you for any help of suggestions you can give me.
kayakcrzy
#2 Posted : Saturday, March 20, 2010 3:37:01 AM(UTC)
kayakcrzy
There is a thermostat in the back of the oven. You would have to pull the oven out, and take the back off, and in the center there is a round part the size of quarter, make sure the oven power is off, when you do this. Anyway, take the two wires off, and put the terminal ends together of the wires you took off, and put some tapr around it, to hold it together, and to make sure the terminal ends don't hit metal, and then turn the breaker on, and see if the control lights up. If it does, replace the thermostat, if it doesn't replace the board. Tom ApplianceEducator.com www.applianceeducator.com/partsd.htm
