celestialspapa
#1 Posted : Friday, March 19, 2010 10:24:30 AM(UTC)
celestialspapa
we are getting a fdl code for the door lock code. is there a fix or does the switch have to be replaced? Is is an easy fix and what is the part #?:eek:
#2 Posted : Friday, March 19, 2010 2:49:39 PM(UTC)
The model number you posted does not come up. It can be incorrect or incomplete. Verify and repost it.
P.S. Look for the tech sheet inside the control panel. The explanation and instructions can be there.
Door Lock Switch Frigidaire (Washer Repair)
by onatoli 12/27/2011 8:13:30 AM(UTC)
Proper Wiring to replacement Door Lock Switch (Washer Repair)
by Teacher123 12/16/2011 1:28:40 PM(UTC)
How to replace door lock switch assy (Washer Repair)
by tsbuck 5/7/2011 4:01:30 PM(UTC)
Door Lock Switch Neptune (Washer Repair)
by Robertydebbie 6/14/2009 10:30:29 AM(UTC)
