bigumper
#1 Posted : Friday, March 19, 2010 7:16:58 AM(UTC)
bigumper
Help Please. I have a nine year old JENN-AIR drop-in range. The lower element is not working. I have replaced it twice. The new elements do not work. the upper element works. The temp light does not indicate the correct reading. I have replace the control panel. What is causing my problem. Thank you, Bigumper
#2 Posted : Friday, March 19, 2010 6:39:21 PM(UTC)
Most likely the problem is a bad relay board (#29 on the diagram).
- The relay board Part number: AP4008573
Lower element not heating (Oven Repair (including Ranges and Cooktops))
by balmoral 10/12/2011 10:20:24 AM(UTC)
by jenny cooker 1/2/2011 4:20:17 PM(UTC)
