DaronDavis
#1 Posted : Thursday, April 17, 2008 7:54:09 PM(UTC)
DaronDavis
My Speed Queen told loader has started leaking oil into the drum. It's not real bad, but it's enough to ruin a load of clothes with oil spots.
Everything works fine, but when it hits the spin cycle it slings small thin streaks of oil out from under the agitator.
I pulled off the agitator, but haven't gone any further.
What I need to know is there a seal I can replace that will solve the problem or is this a larger transmission problem?
If it's just a seal then I'd like to just replace it myself....if it's worse then I may need a new washer.
Any thoughts?
bambiblaster
#2 Posted : Friday, April 18, 2008 2:40:34 AM(UTC)
bambiblaster
Most likely a seal kit shld do part number AP170657
#3 Posted : Friday, April 18, 2008 2:52:13 AM(UTC)
You can go to the web site www.applianceaid.com for info on replacing the tub seal and bearing. This is at least a two hour job and you may need to rent a gear puller to pull the hub off. Please post results if you do this job.
