RobCat
#1 Posted : Tuesday, March 16, 2010 5:08:58 PM(UTC)
RobCat
My front XLo burner sparks but does not ignite. I had the same problem with the rear one a few years ago and a repairman replaced the potentiometer. I wish to do the same now (without the repairman). Any advice on how to access the area and safely replace it? Thank you.
#2 Posted : Tuesday, March 16, 2010 7:45:53 PM(UTC)
Does the gas flow through the burner while the igniter clicks?
RobCat
#3 Posted : Wednesday, March 17, 2010 4:19:04 PM(UTC)
RobCat
Yes. If I turn on the rear burner at the same time, the front burner will also light.
#4 Posted : Wednesday, March 17, 2010 5:22:42 PM(UTC)
The instructions are attached to the reply.
If you need the correct part number for the potentiometer, talk to the APP team.
File Attachment(s):
Removing the control panel PRSG - PRSE.doc (136kb) downloaded 47 time(s).
RobCat
#5 Posted : Thursday, March 18, 2010 1:53:50 PM(UTC)
RobCat
Thank you, Gene. I cannot open the first file. I get a big red 'X'. Can you post it as a PDF?
#6 Posted : Friday, March 19, 2010 2:01:08 PM(UTC)
I've tried to open this file a few times and it did it fine. Unfortunately I do not have such software to convert it in PDF.
Replace Potentiometer (Oven Repair (including Ranges and Cooktops))
by gss2000 9/4/2008 2:37:33 PM(UTC)
