6 Pages«<456
gsam
#51 Posted : Monday, January 18, 2010 8:29:13 AM(UTC)
gsam
Originally Posted by: TMcTx Go to Quoted Post
I got the new switch in, everything works good, except the hot surface light is on all the time. The top is cool and all the switches are all off.
Any ideas.
Tim
Tim I replaced my switch with APP part AP3775555 and the HOT SURFACE LIGHT went off after the burner cooled down. Did you ever fix this? See my comments later in the thread about the issue I had with the "N" connection wires.
GSAM
gsam
#52 Posted : Tuesday, January 19, 2010 3:04:25 PM(UTC)
gsam
I manage to take the pictures of the new switch not easy getting a clean shot.
Notice the following
Red and Pink wires are on the (L2B) connection TOGETHER
BLACK & Grey Wire = (L1)
YELLOW = (H1)
ORANGE = (H2)
BROWN Wires (2) of them = (P)
Pin (L2) is NOT USED
Pin between (L2) and (L1) no label, is not used
Pin between (L2b) and (H1) no label, is not used
This part was used to repair an FRIGIDAIRE FEC3026HSA / Electric Cooktop and may not represent the wiring for another cooktop.
Good luck
gsam attached the following image(s):
MadlockMo
#53 Posted : Wednesday, March 17, 2010 2:06:34 PM(UTC)
MadlockMo
YELLOW = (H1)
ORANGE = (H2)
Good luck
The exact same part was used to replace a Sears #903057-9010 part number, used your diagram and photos on a FRIGIDAIRE FEC30S6HBA. Great job, this is what the internet was invented for not all the other B.S. :D
gsam
#54 Posted : Wednesday, March 17, 2010 7:28:21 PM(UTC)
gsam
I work in technology myself and a picture and diagram paints 1K words. Glad it could help. :)
dfwmga
#55 Posted : Sunday, February 20, 2011 2:03:17 PM(UTC)
dfwmga
Have read the thread, but I was wondering if replacing the switch will make the dual surface operate correctly. Right now no matter which way you turn on the burner (small numbers or large numbers), it always heats on the [COLOR="Red"]full area of the burner[/COLOR]...otherwise everything works fine. Or is there something wrong in the element?
#56 Posted : Monday, February 21, 2011 2:03:11 PM(UTC)
What is the complete model number of the range?
Guest (10)
6 Pages«<456
