rbayer
#1 Posted : Thursday, April 17, 2008 10:25:07 AM(UTC)
rbayer
I have new parts to repair this dishwasher. Trying to loosen the screw holding the wash impellar(the impellar has 6 flats on it to keep it from turning) the motor shaft the screw is screwed into keeps turning but the wash impellar won't turn because of a wrench on the flats. Is there anyway to prevent (lock the motor shaft?) the motor shaft from turning, so the screw will loosen?
Thanks for your help
misterfixall
#2 Posted : Thursday, April 17, 2008 6:14:19 PM(UTC)
misterfixall
there is special wrench for impeller .then use 1/4 inch socket or nut driver. socket is better. some times you have to break impellor to get off ,+get new ne impeller seal kit
#3 Posted : Friday, April 18, 2008 2:39:40 AM(UTC)
You can try a pair of vice grips on the old impeller to get the screw off. Once screw is off, I use a sharp wood chisel to bust the old one off. If you sheer off the screw, you can epoxy the new impeller on
bambiblaster
#4 Posted : Friday, April 18, 2008 2:46:22 AM(UTC)
bambiblaster
You can use vise grips to hold impellar
