My Whirlpool dryer only warms up. Model number LDR3822DQ1. It is a 110V dryer. I checked the heating element and read 10 ohms. I also checked when it was running and it was getting 110 V. Everything else works fine. Any help is greatly appreciated. Thank you.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Thank you for the reply Denman. It did get hotter before. I looked around inside the dryer and I could not find the thermostat. Where is it located? thank you again.
