Bosch dishwasher will not pump the water out. We did find a button that somehow had gone through and lodged in the drain pipe, after the pump may have tried for a couple hours to pump the water out. Now, it pumps water in but not out. Need part number. No local repair in my area.
peggyr
Originally Posted by: peggyr Bosch dishwasher will not pump the water out. We did find a button that somehow had gone through and lodged in the drain pipe, after the pump may have tried for a couple hours to pump the water out. Now, it pumps water in but not out. Need part number. No local repair in my area.
peggyr did you pull out and clean the entire hose from disposal to drain connection on left side?
