bishiman
#1 Posted : Monday, March 15, 2010 2:01:43 PM(UTC)
bishiman
I have a Whirlpool LER4634EQ1 electric dryer and it will not turn on when I push the start button. I used a ohm meter and checked the start button and door switch and both are good. What else can I look for?
Thanks in advance for any help.
magician59
#2 Posted : Monday, March 15, 2010 5:35:56 PM(UTC)
magician59
Check the outlet for 240VAC. Try the dryer in every cycle. If it works in some, but not all, replace the timer.
bishiman
#3 Posted : Tuesday, March 16, 2010 3:12:13 AM(UTC)
bishiman
I have 243 volts at outlet. It does not work on any settings on the timer.
magician59
#4 Posted : Tuesday, March 16, 2010 6:31:34 AM(UTC)
magician59
If the timer advances, you should check the continuity of the thermal fuse(s). Also check the continuity of the door switch. If the timer does not advance, chances are the problem is a bad timer. It can be bad even if it will advance on its own.
bishiman
#5 Posted : Tuesday, March 16, 2010 12:07:31 PM(UTC)
bishiman
Thanks so much. It was the thermal fuse. Works fine now.
