trotwood100
#1 Posted : Monday, December 29, 2008 2:45:43 PM(UTC)
trotwood100
Ok, a repair man just came by and said i need a new magnatron. after he left i found the part in your store for half of what he said it would be. I went to take the microwave cover off so i could verify the part number but alas, the screws holding the case on are wierd, not allen, not phillips, not regular. they look like a star. what type of bit do i need to remove these. and once i do this and get your part is it easy to remove and install?:confused:
magician59
#2 Posted : Tuesday, December 30, 2008 5:59:37 AM(UTC)
magician59
These are TORX screws. Many of them are tamper resistant Torx, at that. They are there as a line of defense against the average homeowner (or below average homeowner) sticking his hands where they don't belong. If you enter your microwave cabinet and come into contact with a charged capacitor, you may just leave a part of you behind, in reacting to the serious jolt you receive. If you must open the cabinet, FIRST unplug it. Then, discharge the capacitor by shorting between the (+) and (-) terminals, before you commit your hands to the job.
JohnCrabtree007
#3 Posted : Monday, March 15, 2010 2:39:37 PM(UTC)
JohnCrabtree007
Where can I get a Torx screwdriver?
magician59
#4 Posted : Monday, March 15, 2010 5:33:57 PM(UTC)
magician59
Almost anywhere you can buy hand tools will also sell Torx screwdrivers. Take a close look at the screws. If you see a pin in the center of the Torx socket, You need the tamper resistant Torx drivers.
