ge side by side w/ice maker and ice/h2o in the door. The Ice maker works fine both crushed and cubes. Water will not dispense. Just replace filter several weeks ago. Was working fine and all of the sudden stopped.
Check if the water tank (on the bottom in the refrigerator section) and tubes are not frozen. You can defrost them, carefully using a hair dryer. Locate the water inlet valve on the back of the fridge. Check for 120V to the water dispenser coil (5/16" tube) while the dispenser calls for water. If there is 120V - replace the water inlet valve. If there is no 120V - replace the main control board (on the back of the fridge). - The part number for the water inlet valve is AP3192626 - The part number for the main control board is AP3950129 Gene.
