napradoc
#1 Posted : Monday, March 8, 2010 5:49:53 AM(UTC)
napradoc
Kenmore elite Calypso motion washer, I do not have the owners manual.
Lately I have been getting error messages of C1 or is it CL, and also FL. Seems to stick on these messages, if I unplug it for several hours and then restart it, it SOMETIMES continues to run. Any suggestions or help would be appreciated.
Steve
sidfink43
#2 Posted : Tuesday, March 9, 2010 4:13:13 PM(UTC)
sidfink43
See if you can use this service manual to put it into test/diagnosis mode and determine what the issue is.
https://secured.whirlpoo...4632a4/$FILE/8178010.pdf
napradoc
#3 Posted : Monday, March 15, 2010 4:54:25 AM(UTC)
napradoc
Thanks for the manual, I ran it through the dianostic tests but nothing came up. Still getting error messages of LD,CL, and especially FL. Still have to unplug it for quite a while before it will pump out the water and start running again. Any other suggestions would be appreciated. !!
Steve
sidfink43
#4 Posted : Monday, March 15, 2010 5:35:49 AM(UTC)
sidfink43
In this situation you want to do things that cost the least amount of money. I would start by taking off the pump and thoroughly cleaning it out along with the drain hoses.
Let's see what that does, if anything, for you.
napradoc
#5 Posted : Monday, March 15, 2010 6:08:52 AM(UTC)
napradoc
Thanks, I'll give it a try. I've also noticed that after letting it sit and plugging it back in the FL message flashes and it just hums. Does this change your approach any??
Steve
sidfink43
#6 Posted : Monday, March 15, 2010 6:17:25 AM(UTC)
sidfink43
Everything you state points to a machine control board problem, but since that is pretty expensive and requires a replacement to confirm, try the cleanout first, and also take off and clean and reseat all the connections.
napradoc
#7 Posted : Monday, March 15, 2010 9:53:17 AM(UTC)
napradoc
O.K. I haven't tried to clean it out yet, but when I run the self diagnosis program the countdown timer stops at 33. Does this help give you a better idea about whats going on.
Steve
sidfink43
#8 Posted : Monday, March 15, 2010 11:37:03 AM(UTC)
sidfink43
Sorry, same opinion, if cleaning the drain/pum and the connections and reseating them does not help I am afraid you will have to try with a control replacement.
napradoc
#9 Posted : Monday, March 15, 2010 12:17:24 PM(UTC)
napradoc
Would that be the electronic control board or the motor control board you are talking about, not sure which one you mean.
steve
sidfink43
#10 Posted : Monday, March 15, 2010 12:30:13 PM(UTC)
sidfink43
Main Control Board should be the source of the problem.
Hopefully it won't come to that.
Guest (4)
