Hello, my dish washer does not drain. the hose is clear. Is there another area on this model that I need to check. thank you for your help.
THIS FORUM IS DEAD!!!!!!! |
Thank you for the quick response. Will check it further this weekend.
Hosde was clogged deep deep inside. problem solved. thank you again.
