My Samsung C100T suddenly stopped working. One day I found it completly dead, without any explanation. I found that the small "monitor fuse" was blown, probably indicating that one of the door switches (three in my case) were broken or not working correctly.
However, I checked those (in place) and they are ok. I replaced the fuse, but it blowed again as soon as I applied the power (door closed).
Since I didn't powered on the magnetron, I don't believe that it could be short-circuited or anything else around it.
Any idea of what could be wrong ? I'm electronician (but not oven techician :) ) and can't find anything wrong. The control board seems to work perfectly when powered separetely.
Thanks for helping !
Matthieu, from Belgium
