My Kenmore Elite dishwasher model 665.15989990 starts leaking water as soon as it is turned on. Water is running down on the left side onto the floor as you face the the front of the dishwasher. Water is running down the water inlet hose. I removed the water inlet hose and there is no hole in the hose. Also the hose clamps did fit tight. I guess the leak is above the water inlet hose. Maybe the Water inlet assembly? Any suggestions? Thank you.
Here is the tech sheet. http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208051291.pdfYou will have to see the leak to be able to troubleshoot it. This may involve pulling the unit forward out from under the counter a foot or so. You may be able to push the insulation on that side back enough to see what is going on. You could get your self a flashlight and a small mirror, they can be very useful when trying to locate a leak. |
THIS FORUM IS DEAD!!!!!!! |
