iraslotnick
#1 Posted : Saturday, March 13, 2010 6:08:13 PM(UTC)
iraslotnick
Model No KUDS01JSP0.
Water entering fine and draining fine but skips wash cycle. Tried replacing Control Panel but wash cycle still does not work. Ideas?
#2 Posted : Sunday, March 14, 2010 1:37:09 AM(UTC)
Views messages in topic : 19,638
Could not find a 01JSP0 . The following is for a 01DJSP0
Replacement parts for WHIRLPOOL KUDS01DJSP0 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf
And a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d/$FILE/KD01.pdf
Sounds like the motor may be toast.
Check the windings with a meter.
Could also be a bad wire from the control to the motor, a bad capacitor or a partially shorted winding though you usually hear the motor buzz or a jammed motor.
iraslotnick
#3 Posted : Sunday, March 14, 2010 8:15:14 AM(UTC)
iraslotnick
http://www.servicematters.com/d...0Sheet%20-%208269519.pdf
And a manual
https://secured.whirlpoo...800643b6d/$FILE/KD01.pdf
Thanks. You have the correct Model. Sorry about that. Questions:
1) if the windings test badly does that mean I need to replace motor?
2) How do I access motor? Is motor accessable from the front - or do I need to pull out the dishwasher and turn it upside down?
3) Do I order new motor AND pump or are they the same?
4) I do see a wire from the control panel leading down somewhere. Is this the (possibly bad) one being referred to in your reply?
5) Is the capacitor easy to replace if the motor is good? (Though I don't hear a buzz)
#4 Posted : Monday, March 15, 2010 11:16:26 AM(UTC)
Questions:
[COLOR="Blue"]1) if the windings test badly does that mean I need to replace motor?[/COLOR]
Yes
[COLOR="Blue"]
2) How do I access motor? Is motor accessable from the front - or do I need to pull out the dishwasher and turn it upside down?[/COLOR]
Depends on how good you are at working in tight places. You may have to pull it out some but should not have to turn it upside down.
[COLOR="Blue"]
3) Do I order new motor AND pump or are they the same?[/COLOR]
Comes is a number of ways(just the motor 20, the pump/impeller 10 or the entire assembly 14) see section 8 in parts.
[COLOR="Blue"]
4) I do see a wire from the control panel leading down somewhere. Is this the (possibly bad) one being referred to in your reply?[/COLOR]
Just trace the ones back from the motor.
[COLOR="Blue"]5) Is the capacitor easy to replace if the motor is good? (Though I don't hear a buzz)[/COLOR]
Not very difficult.
