AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer stops, needs door pushed tighter to start up
My dryer is making me pull my hair out! On any drying cycle, my gas dryer stops mid-cycle leaving clothes wet! This has been going on for quite awhile and it's driving me mad. The first time I found it mid-cycle, clothes wet, dryer off-- I pushed the knob to turn it back on. But no response. Eventually after m any days of aggravation, I figured out that, although the door seemed perfectly tightly closed, it was not. If i push the door hard where the door-clip connects, and then push the knob to start up....it works! This consistently wiull start the dryer bac k up. Sometimes, while I am still standing there it will stop again, OR maybe it will work until the load is dry, or maybe it won't. What's wrong?! Can I fix this?
Here are your parts Replacement parts for MAYTAG MDG3757AWW Dryer - Gas | AppliancePartsPros.comFirst check that the hinges etc. are OK Could be just the latch is worn or the female side may be moving in/out of the frame, see Item 22 in Section 2. Could the the door switch itself. A jiggery pokery repair for this might be to get a small fiber self stick and put it on the door so that it pushes the switch in further when the door is closed. The self stick I am referring to is the ones they use on cabinet faces so the doors do not slam. |
THIS FORUM IS DEAD!!!!!!! |
Great! Thanks for the tips...I'm going to look into this NOW, so I can once again find dry clothes instead of wet!
Dryer Repair
