amcconnell
#1 Posted : Wednesday, August 29, 2007 10:35:55 AM(UTC)
amcconnell
I have a Whirlpool GVW9959KQ2 washer, it fills up with water but then won't switch to the next step. Someone mentioned that it probably needs a mother board (also known as a motor control board). Is there any other reason this problem may occur other than what was listed in your troubleshooting guide? Is there a different part/controller that may need replacing instead of the entire board? If I change to rinse it won't fill up again, but will drain, so it may be stuck at aggitate.
#2 Posted : Wednesday, August 29, 2007 7:48:17 PM(UTC)
Hi amcconnell
The answer on your question was posted here:
http://forum.appliancepartspros...load-washer-problem.html
Washer wont aggitate, spin, or drain. (Washer Repair)
by gdavies07 5/2/2011 11:37:07 AM(UTC)
washer wont aggitate (Washer Repair)
by hawkinscollette 4/10/2009 9:42:00 AM(UTC)
