jes1526
#1 Posted : Friday, March 12, 2010 5:51:37 AM(UTC)
jes1526
replaced board and it blew. appears to be blown by marking comp does this mean the compressor is bad???
magician59
#2 Posted : Friday, March 12, 2010 6:01:50 AM(UTC)
magician59
I couldn't hurt to test your compressor before replacing the board again. A simple resistance test should tell you if the compressor is good. Although, it isn't unheard of for the board to be bad right out of the box.
jes1526
#3 Posted : Friday, March 12, 2010 6:10:31 AM(UTC)
jes1526
the fans came on when i plugged in the new board and sounded like the compressor kicked in, so the board was not bad out of the box. how do you do a resistance test??? is there anything else that could cause the board to blow beside the compressor???
jes1526
#4 Posted : Friday, March 12, 2010 7:32:35 AM(UTC)
jes1526
The Compressor Is The Cause. It's Bad, No More Maytags!!
#5 Posted : Saturday, March 13, 2010 6:13:10 AM(UTC)
You show your unit to be 1 to 5 years old.
Most units have a 5 year warranty on the sealed system so I would check the operators manual.
