ceesranch
#1 Posted : Thursday, August 20, 2009 4:25:12 PM(UTC)
ceesranch
When motor is supposed to run it it will jerk but not spin. when power goes off motor spins very freely. This is the original motor so controler is mouted on the back of it instead of a seperate unit as in replacement kit. when I removed the cover over the control board (on mtr) I can see a burnt resistor. Looked at Main control board don't see anything burnt. Any way to be sure it is just the controler on the motor? Also any possible way to identifiy the burnt resistor and safe $185.00 for motor and controler replacement?
ceesranch
#2 Posted : Friday, August 21, 2009 12:45:20 PM(UTC)
ceesranch
The Resistor is R5 any ideas on what size it is? I wanted to try to put a new one in the board. Any suggestion on trying this?
dsukstorf
#3 Posted : Thursday, March 11, 2010 12:35:44 PM(UTC)
dsukstorf
I have the EXACT same problem. What did you end up doing to solve it? Replace the motor?............did it fix the problem?? Did you ever find out what the R5 resistor value is ??? Any help would be greatly appreciated.
magician59
#4 Posted : Thursday, March 11, 2010 1:41:38 PM(UTC)
magician59
What colors are the bands on the resisror?
dsukstorf
#5 Posted : Thursday, March 11, 2010 1:44:49 PM(UTC)
dsukstorf
unfortunatly, resistor is too burnt to read the color bands
#6 Posted : Friday, March 12, 2010 3:07:55 AM(UTC)
If you have a meter, you can pull the service sheet from behind the kick panel and follow the diagnostics for this problem.
