My Evap Coil has been freezing up. Replaced the Thermotransistor about 2 months ago, and had no problems again till now! Do not see that the defrost cycle is ever starting. Don't have a Meter and can't check the continuity of my Evaporator Heater! Since this Fridge runs the Defrost Cycle on an electric cycle (NOT MANUEL), I was wondering what the likely hood could be that the Board that controls the Defrost Cycle was bad? And if so Which Board would I need. I followed the schematic chart, but would like a second Expert opinion (KEY HERE IS EXPERT!).
Thank You Mark!
Also, I was manually defrosting yesterday and I kept the refrig plugged in, but turned Freezer controls off! When the Evap was defrosted the freon started condensing (HEARD THE SWISHING NOISE) and the Evaporator Coil started instantly frosting. Shouldn't the freezer have not been operating due to the Freezer Controls being turned off? This may also lead to the board being defective, also?
