Hi All- Thanks so much for checking this out. SO here's whats going on with my oven. The gas burners work fine. The broiler works fine. The regurlar use of the oven isn't working. When I turn it on to preheat, the fan goes on, as it always does, and then stays cold. Any ideas? Thanks so much again. L
Start by looking for the igniter to glow when you select "Bake". If no glow, replace the igniter. If you do see it glow, more diagnosis is needed.
