replaced the drum bearing with the kit, but noticed my drum is misaligned and has been for some time due to the wear i can see. i tried to thicken the felt on the side it was closest to the door but it eventually spit the felt out and then back to eing misaligned, any ideas are helpfull i can even send pictures of it if you would like.:confused:
Most likely that something went wrong while the drum was installed back. I would take it apart and carefully reassemble.
Gene. The model number you posted does not come up.
