guardmom768@comcast.net
#1 Posted : Wednesday, March 10, 2010 9:50:56 AM(UTC)
Have a one piece whirlpool Gold Over/microwave. Three months ago the microwave started making a loud humming noise when turned on and does not heat at all. Worked one minute, and the next did not. Will not heat anything. Oven below works and all electronics work. Only loud humming and no heat. Was told by someone it would cost around 1000.00 to fix. I am so upset. What could possibly be wrong with the microwave. It did not get a lot of use to "wear out" either. Please help. Thanks
magician59
#2 Posted : Wednesday, March 10, 2010 10:26:36 AM(UTC)
magician59
If it constantly hums and does so every time you try to use it, I would lean toward a bad power transformer. Part number: AP2929274
#3 Posted : Wednesday, March 10, 2010 10:40:12 AM(UTC)
Thanks...The humming is more like a very loud buzz. Do you think this could be repaired by someone who knows a little bit about doing this, or should I be safe and call a repairman. They want to replace more than the transformer. They also want to replace the Cap and Diode, Magnetron and the transformer.
magician59
#4 Posted : Wednesday, March 10, 2010 10:46:24 AM(UTC)
magician59
That's "Replacement Therapy". It's an indication that the individual doesn't know how to troubleshoot. We can help you in this process, if you have and know how to use a meter.
#5 Posted : Wednesday, March 10, 2010 11:02:57 AM(UTC)
Great...Will wait for my husband to get home. He knows how to use the meter.
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Replacing Handle on Whirlpool Microwave GH4184XSS1 (Microwave Repair)
by barbhickman13 8/28/2022 7:09:07 AM(UTC)
Whirlpool microwave LED (Microwave Repair)
by kafka45 3/20/2021 9:48:06 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Whirlpool microwave ovens countertop (Microwave Repair)
by boxershubhammm 9/23/2019 10:06:07 PM(UTC)
Whirlpool Microwave Door Sensor Part & Diagram? Need help (Microwave Repair)
by ellie0704 4/8/2019 8:26:28 AM(UTC)
Whirlpool Microwave Door Error and flipped breaker when plugged in (Microwave Repair)
by ellie0704 2/9/2019 9:12:28 AM(UTC)
Whirlpool Microwave stopped working (Microwave Repair)
by Myron S 12/19/2017 4:21:39 PM(UTC)
Whirlpool microwave open/close door (Microwave Repair)
by jigrami 3/6/2017 12:45:32 PM(UTC)
Whirlpool microwave door handle broke (Microwave Repair)
by troyw66 11/9/2016 6:32:52 AM(UTC)
Whirlpool microwave vent fan not working (Microwave Repair)
by mshaw8099 7/22/2015 2:07:41 PM(UTC)
whirlpool microwave code F1E4 mw power relay (Microwave Repair)
by sja527 12/21/2014 3:36:17 PM(UTC)
Whirlpool Microwave died... (Microwave Repair)
by michaellawre 7/4/2014 2:24:47 PM(UTC)
Whirlpool Microwave Started Smoking (Microwave Repair)
by mharnisch 1/15/2014 12:48:02 PM(UTC)
Whirlpool Microwave not heating (Microwave Repair)
by ddelay 10/15/2013 5:16:23 PM(UTC)
